Moving an object to a specific location
Command |
Path |
Move Geographic |
Modify > Move |
You can move an object in a georeferenced file to a different geographic location.
To move an object geographically:
Select the object to be moved.
Select the command.
The Move Geographic dialog box opens.
Parameter |
Description |
Move to location |
Moves the selected object to the specified Latitude and Longitude |
Latitude/Longitude |
Specifies the latitude and longitude to which the object will be moved; enter decimal degrees, or degrees/minutes/seconds (for example, 39.18, 39° 10’ 32”, or 39d 10m 32s) preceded by a minus (-) sign when appropriate |
Move relative |
Moves the selected object from the current location using the specified Azimuth and Distance |
Azimuth/Distance |
Specifies the direction in degrees (0° is the Y axis, 90° is the X axis), and the distance the object will be moved, in document units |
